KenLark
Dec 28, 2012Aspirant
Powerline Distance
Haven't been able to find a spec for the distance a powerline adapter signal should travel, does anyone know? Apart from the spec, any input on real world distance? Mainly concerned with neighbors bei...
KenLark
I'm aware there is encryption available and that within the same circuit it should be safe. Again, looking for what the spec is for distance. Thanks!
