jmizoguchi's avatar
jmizoguchi
Virtuoso
Jan 04, 2013
Powerline HDX101 what's compatiable?
Any HDX family should work with it
  • Hi I have two HDX101 powerline units connected to my Netgear router. I want aniother two but there no longer available.
    Does anybody know ( or has already connected) if the Netgear 200Mbps Mini will work with the HDX101 units please.
    Thank You
    Andy
    Thank you for your reply but, as far as I can tell Netgear don't make the HDX family of POE devices any more. I cant see any on their website.
    Can you point me to them please or an alternative that will work with the HDX units.
    Regards
    Kili
  • jmizoguchi, thank you for your reply. I have contacted support and they sum up with
    "And we also would like to inform you that the HDX home plug will only work with an another HDX device. "
    I assume this means it wont work with an XAV device or support wrong?
    Many Thanks for your time
    Kili
