JRV1
Sep 08, 2020Aspirant
PowerLine network topology
3 story house with wi-fi equipped cable modem on one end of 1st floor. We need Wi-Fi at the opposite end of the house on 2nd & 3rd floor. We currently have a 5 or 6 year old powerline network a...
- Sep 08, 2020
Not unless you go through a reseller who's seperated them out. But powerline devices are compatible with a spec. So long as other powerline devices use that same specification, they'll work together. And other companies sell them seperate.
Sep 08, 2020Guru - Experienced User
You only need 1 plugged into the modem/router. the rest will connect back to it.
JRV1
Cool, thanks! They appear to be sold in sets though. Are they available separately?
- plemansSep 08, 2020Guru - Experienced User
