huibertus69's avatar
huibertus69
Follower
Nov 04, 2019
Powerline PL1000 for differant electrical groups
I have one Powerline set which functions fine. The transmitter and reciever are connected on the the same electrical group. I want to install another set because I want an ethernet connection on a different spot which is not connected to the same electrical group as the other set. Therefore, I installed another set and connected the transmitter to to switch but that caused my internetconnection to go haywire. If I only connect the new reciever (whcih is not connected to the same eletrical group as the transmitter) the performance is to low. Can this in any way be solved?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What is an electrical group?
    All plugs on your powerline network have to be on the same electrical circuit. That's the whole idea.
