Antaine
May 17, 2020Aspirant
Powerline PL1000 loss of speed
hi there I have home internet via 4G mobile broadband device. I average about 50MBPS. I have tried to use the powerline adaptor to extned the range to my home office. one PL is connected to the wi...
May 18, 2020Guru - Experienced User
many things impact powerline.
it could be.
1. The old wiring.
2. arc fault breakers
3. gfci outlets
4. surge protectors
5. bad/cheap cell phone chargers
6. cheap electronics injecting noise in the line
7. high draw appliances
8. even electronics that are going bad could cause noise in the line
9. Distance is hard to predict with powerline because everything traces back to the main breaker board. Technically your device might be closer, but the wiring might actually be causing it further apart.
You might be right that an extender might be a better option. You can try troubleshooting by unplugging devices to see if its something injecting noise into the line. Easy test? put both powerline devices on the same circuit without anything else plugged in. If they do fine, they're functioning fine and its one of the things above.
