android_roy
Jul 22, 2019Guide
Powerline PL1200 Speed is Very Slow
Recenty purchased the PL1200 at Best Buy. Configuration: SurfBoard gigabit capabe modem connected to Spectrum gigabit service (verified 1.3 Gbps coming into the house); Nighthawk X6, Tri-Band Wi...
android_roy
Jul 23, 2019Guide
The download speed and upload speed. I used Speedtest by Ookla website on the connected laptop. I was able to get as much as 50 Mbps last night. Which is way less then this product advertises. This house is new and is even wired with Ethernet everywhere except the room I’m working in which is why I bought the PL1200. I also used Googles speed-test capability and got about the same. The modem is pushing about 1.3 Gbps download speeds, the router (Nighthawk X6) is also pushing about 1 Gbps download speed wired, and about 500 Mbps wireless via 5GHz. So I’m confident that the bottleneck is either in this device or my wiring.
michaelkenward
Jul 23, 2019Guru - Experienced User
More questions, I'm afraid.
Connected how? Wifi? Wired Ethernet?
And what is this laptop?
Does it deliver faster speeds elsewhere?
- android_royJul 23, 2019Guide
I'm sorry I do not understand your questions. I thought it would be very obvious, however if you think you can help, here you go, and thanks in advance.
Room 1:
ISP --> Modem (Surfboard Gigabit-capable, 1.3 Gbps) ---> Netgear Nighthawk X6 Router (1.0 Gbps wired/500 Mbps wireless via 5GHz) ---> PL1200 (a) (connected via CAT6 to closest electric plug 14 ft away).
Room 2:
PL1200 (b) ---> Dell Docking Station via 25 ft CAT6 ethernet.
I've tested each segment, and noticed between PL1200 (a) and PL1200 (b) I am only getting (at best) 45 Mbps download speed.
WRT your questions:
1. Wired via CAT6 Ethernet
2. This laptop is a Dell with a Gigabit NIC
3. Yes, I get close to 300 Mbps via wireless (WiFi 5GHz). However, wired connection needed to support home office requirements.
I'm thinking its the specific device, but has anyone ever gotten over 50 Mbps speeds?
- michaelkenwardJul 23, 2019Guru - Experienced User
Funny that, you seem to have answered them.
Perhaps you mean that you don't understand why I asked them.
I asked about the laptop because too many people turn up with devices that have 100 Mbps LAN and then complain that they cannot get speeds of Gbps.
I asked about the wifi/LAN connection because people often turn up here and wonder why their 2.4 Ghz wifi clients can't get Gbps wifi speeds.
I am not familiar with Dell docking stations, so have no idea if that could cause a speed hit.
I usually also ask about firmware on the router and the modem in the chain. Newer firmware can fix things that slow down a router. (Did updates can also slow down a router.) A modem that is also a router can cause "double NAT" problems that slow down, or disrupt, a network' although that would manifest itself without the intervention of Powerline plugs.
Any attempt to understand, and perhaps solve, problems, depends on knowing as much as possible about what is going on at the user's end.
I have PL1200 plugs that don't seem to have such a speed hit. However, my Internet connection is limited to 60Mbps.
Yes I was confused about why you asked and the type of questions, in my mind stating that I'm using the PL1200 was said with the assumption that things would be wired (Ethernet). LOL. No worries.
The modem is new (less then 30 days), verified speed downloads of 1.3 Gbps. The Router (separate device) is the Netgear Nighthawk, and is new as well (less than 5 days). The PL1200 devices are also under 5 days old.
Thanks for your input.
