android_roy
Jul 22, 2019Guide
Powerline PL1200 Speed is Very Slow
Recenty purchased the PL1200 at Best Buy. Configuration: SurfBoard gigabit capabe modem connected to Spectrum gigabit service (verified 1.3 Gbps coming into the house); Nighthawk X6, Tri-Band Wi...
android_roy
Jul 31, 2019Guide
I have 900 Mbps to 1.0 Gbps coming out of the router (ethernet-connected) at a distance of 21 feet, and yet via the powerline adapter I'm barely getting 45 to 50 Mbps. That's why I'm obsessing. My bad.
Neldel
Oct 11, 2019Initiate
Same problem. My PL is the one with passive socket. If i remove everything that's plugged into the wall sockets on both ends and just leave the PLs, i get the higher limit= 75mb. In real world, with everything hooked up (pc, modem, router, tv, xbox, etc, i get the lower end of the spectrum - about 65mb.
Have you solved this issue?
