JustaWaveform
Jul 31, 2019Aspirant
Powerline PL1200 will not transmit ethernet after power surge
Hello, My house recently had a power surge from a nearby lighting strike, and now my powerline adapters will not transmit ethernet. The switch it is connected to, a Netgear Orbi, works just fine ...
Jul 31, 2019Guru - Experienced User
Lightning does a great job of wrecking electronics. Especially powerline equipment and routers.
You've tried resetting them. Excellent.
Tried moving them to the same room/circuit.
have you tried accessing them using the netgear genie?
another option is search for support of Zyxel PLA5405 adapters on their own (zyxel) website. This utility has worked on the pl1200 before.I haven't seen a utility directly from Netgear but the zyxel one has been known to connect. Might give you a means of accessing the powerline device
JustaWaveform
I have not tried the Genie, but I'll keep that in mind when I get off work. I'll keep you posted if they cooperate or not.
- michaelkenwardAug 01, 2019Guru - Experienced User
