laworder
Mar 15, 2023Aspirant
Powerline PLW1000v2 "no valid IP address"
Have installed one of these, initiall I got it working and it ran well, very fast, but it stopped working this morning. I have all the correct lights according to the manual, I have Wifi but no inter...
michaelkenward
Mar 16, 2023Guru - Experienced User
laworder wrote:
I have Wifi but no internet on laptop, shows Connected, secured but no internet access.
That could be down to the laptop. Windows is great at blocking access to new networks. Try telling it "Private" network.
Windows 10?
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
Windows 11?
- Ethernet
- Properties
- Private
On the Samsung, is it a new one? They have taken to using the "security" move of creating random Mac addresses, along the same lines as Apple:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
laworder
Mar 16, 2023Aspirant
It was working on the same laptop prior to this (and has now randomly started working again several hours later)
The Samsung is about 3-4 years old. Partners Samsung tablet and phone also werent connecting yesterday
Powerlines are plugged directly into power sockets at both ends
- michaelkenwardMar 16, 2023Guru - Experienced User
So it is fixed now? With no intervention on your part?
- laworderMar 17, 2023Aspirant
Yes, it came up with no intervention from me (or anyone else as far as I know, I'm the tech person in the home)
Still up so far so good.
I am starting to wonder if this is something to do with the power saving feature kicking in and the router dropping the DHCP to the LAN port as a result and not starting it up again when we go to use it again
Also cant log into the mywifiext page for this, never have been able to, get connection refused. If I was able to get into that would I be able to turn off the power saving from there? The miniscule amount of power saved is not worth the hassle!
- michaelkenwardMar 17, 2023Guru - Experienced User
Good thinking. That has been an issue with Powerline plugs.
Unfortunately, Netgear no longer provides management software for its plugs. But the programs from other brands seem to do the job.
How are you going about it? If you can find its IP address, throw a browser at that. Might let you in.
Not sure that you will find the power settings in there. I no longer use my WiFi plus. Instead, I use the plugs to connect AP devices to the network.
