quadcam
Mar 03, 2012Follower
powerline to detached garage
I have a detached garage about 75' from my house and I'm trying to find out if a powerline network would be a good solution to expand my dsl connection since my wifi signal from my router doesnt quite...
Eskimo1
Apr 26, 2012Aspirant
I should add, I was a little off on the path the signal has to take...
Wire feet is:
1- ~25' from the first AV200 to the subpanel that outlet is wired into, through the breaker.
2- 3' to the 100A breaker for that feed.
3- Through the buss in the main box.
4- Through another 100A breaker for the garage subfeed.
5- ~75' from house panel to garage sub-panel.
6- Through the 100A breaker in the subpanel, then through a 20A breaker.
7- 3' to the outlet where the other AV200 is.
So yeah.. A little over 100' of wire, but also 5 circuit breakers!
Wire feet is:
