Rustee
Apr 07, 2013Aspirant
powerline utility + adapter problems
Hi! I'm using xav5001 adapters between my router and computer, which is a stretch of about 6-7 meters and 2 different powerlines inside the house. I've got the utility working at last, but when ...
uploader
Aug 15, 2013Novice
I had a problem with Powerline utility v3.1.0.4 i always got the error "NamePipeServer has stopped responding!"
And the prblem was that i have dual LAN motherboard and when they are both in use the powerline utility doesn't work properly...and when i disable the LAN which is not connected through Powerline adapter, then Powerline utility works just fine!
