Obi1knobby
Sep 09, 2013Follower
Powerline utility D 3.1.0.4
Hi
A quick question
i had a XAV101 (master pluged into router) and a XAV1004 no problems
Today i bought a pair of ZAVB1301 to add to my network
at the start i could not get the 1301's to connect to the network at all
i swapped the 101 for a 1301 as the master after a little hair pulling
they have all conected (seemingly)
i then downloaded the powerline utility to see the network but no matter what i do i can only see the 1004 on the computer screen, is this normal or should i see all the devices?
thank you in advance
Paul
A quick question
Paul
1 Reply
- ruscroftAspirantI have a similar problem I have 2 powerline adaptors which I have had for 1.5 years the are working since I can stream to my TV from my desktop using them.
The Utility will not recogise they exist on the network
I have one powerline 'Ethernetted' to my home hub and one to my TV
My desktop PC is also 'Ethernetted to my home hub
If I attach my computer directly to one of the devices the utility recognises the device the computer is 'Ethernetted' into but not the other one.
Extremely frustrating since when I bought them there was no problem whatsoever in seeing them on the network.
