rc51
Nov 04, 2023Aspirant
PowerLINE WiFi 1000 (PLW 1000) bought second hand
I have bought a second hand Powerline WiFi 1000….I am not sure if I am entitled to any sort of support but my thinking is….if I don’t ask I will never know. Anyway, here goes. The item is as new an...
- Nov 05, 2023
rc51 wrote:
that’s why we have passwords so someone cannot do what I am trying to do.
The Factory Reset button is on the bottom. See page 7 of the user manual.
Page 14 describes using the reset button.
Anyone who has physical access to an electronic device can reset it to factory specifications and erase all passwords and configurations. Passwords can prevent access to information. They cannot prevent someone from reusing a device with new passwords.
rc51
Nov 05, 2023Aspirant
Thanks to all. With your support and assistance, and switching on my aging grey matter, I have achieved success.
michaelkenward
Nov 06, 2023Guru - Experienced User
That's good.
With luck the SOLVED flag will guide anyone who turns up here later seeking help.
- rc51Nov 06, 2023Aspirant
The solution turned out to be simple but I would put it down to my lack of knowledge of and experience with new technologies. The Quick Start booklet did not indicate where to find the password for the Netgear##-EXT network when installing the adapters. The more comprehensive user manual I was directed to explained that the password is actually on the product label on the adapter and there it is called the ‘WiFi Key’.
- michaelkenwardNov 07, 2023Guru - Experienced User
rc51 wrote:
...the password is actually on the product label on the adapter and there it is called the ‘WiFi Key’.
That's pretty standard practice for modems and routers.
The "WiFi Key" or "Network Key" label seems to have given way to "password" among users. Netgear still uses the other label. At least they sometimes add "(password)" to the label.
