Visionr40
Mar 28, 2019Follower
Powerline WiFi 1000
Where can I but just the adapter to add to my network already have one with PL1000 powerline adapter and want to extend network.
Usually if you're only looking for one, amazon or ebay is your best bet for single powerline devices.
plemans is right. But if you want "new", then other brands might sell singletons.
Most recent Powerline devices follow the AV standard, which means that you can mix different makes and different generations. The only issue if that if you add "1000" plugs to a network with "500" plugs they will talk to each other at the speed of the slowest plugs on the network.
