rogerchevrel
Aug 05, 2022Follower
Powerline wifi 1000
I have installed powerline Wifi 1000 = 1 device PL1000v2 + 1 device PLW1000v2 I wish to install another WIFI device . On Netgear catalog I do not find a PLW1000 v2 ! Which compatible unit can I...
Aug 05, 2022Guru - Experienced User
You can add powerline adapters to it.
Sadly, netgear doesn't sell them individually though.
so you either buy a kit and add each in or you go with another manufacturer as as long as it follows the powerline spec, it can be added in.
Adding a powerline adapter to an existing powerline network | Answer | NETGEAR Support
