erica100
Jul 27, 2014Novice
Powerline with 2 panels
Hi everyone, I am new to the forum and wiring. I hope you guys can help. My home has some dead spots for WiFi. I had a addition put in place a few years ago and the addition has a separate el...
michaelkenward
Jul 28, 2014Guru - Experienced User
Whether this will work or not depends on the exact arrangement of the power system.
I have something that sounds to be very much like your arrangement. Two buildings. Each has its own separate circuit. But they both come off the same meter. I can connect through powerline, even though I did not expect this to work.
I discovered this because I was trying to create two separate powerline circuits, one in each building, and discovered that the two circuits are not as isolated as I thought.
