erica100
Jul 27, 2014Novice
Powerline with 2 panels
Hi everyone, I am new to the forum and wiring. I hope you guys can help. My home has some dead spots for WiFi. I had a addition put in place a few years ago and the addition has a separate el...
fordem
Jul 28, 2014Mentor
There's only one way to find out - try it and see - buy your equipment from someone who will allow you to return it if it does not work.
Powerline networks are not known for either predictability or reliability - it will sometimes work up & down the entire block, across half a dozen different homes, and other times it won't work on opposite sides of the same room - and in either case, it can be affected by any change in the appliances in your home/office or your neighbors.
