Jameson
Dec 29, 2011Follower
Problems with Xe104
I have been fighting for this thing off and on for the past week and finally just went out and bought a wireless usb. The unit has worked fine since I purchased it over the summer and is now retired ...
tpcguy
Dec 30, 2011Guide
Hi,
Just read your post, this is a wall-plugged ethernet adapter or switch. Since you are having problem with the speed of connection, have you tried using both powerline adapters on the same room to isolate?
Thanks,
Thanks,
