arnoudv
Apr 21, 2025Follower
Purchase PLW1000 WIFI AP separately?
Hello, I have the Netgear PLW1000, which consists of 1 Powerline 1000 adapter and 1 Powerline Wifi 1000 access point: https://www.netgear.com/support/product/plw1000/ It has been working well s...
michaelkenward
Apr 23, 2025Guru - Experienced User
plemans wrote:
I haven't seen it but I'm sure there's some on the 3rd party (used) market.
That could be easier to set up than a different brand. Same familiar controls.
I have mixed brands. But not the wifi version.
You can also use a wired only Powerline plug to connect a wifi extender in AP mode. That would actually provide a more capable wifi source than the minimalist extender combination plugs. It might be easier, and cheaper, to lay your hands on a wired plug.
Disclaimer: Just another user with time on their hands.
datatech451
Apr 30, 2025Aspirant
The PLW1000 is typically part of Hikvision's Power over Ethernet (PoE) and WiFi solutions, often bundled with PoE switches or NVRs.
Availability as a standalone product may vary depending on your region and supplier.
