Aidelimo
Jul 30, 2021Tutor
AV 200 Adapter XAVB2001
Hello, I have two Netgear Powerline AV 200 Adapter XAV2001 cpl sockets, I would like to buy two or three new Netgear cpl sockets to work together, but I cannot understand which model of socket to bu...
Jul 31, 2021Guru - Experienced User
1. Yes the powerline device you linked to would work. But it'd only function at the speed of the slowest powerline device on your network.
2. That wifi extender isn't a powerline device. It could pick up and repeat the wifi signal from your router but it doesn't have integrated powerline so it wouldn't connect via that route.
3. It isn't "secondary" powerline device. You only need 1 that connects to the router and is the "source". the rest are added to the network its setup.
Aidelimo
Jul 31, 2021Tutor
Perfect !
Thank you very much for your time!
