MarthaCR's avatar
MarthaCR
Samsung smart TV not accessing network connection AV 500
I have a samsung TV hooked to my AV 500 adaptor via ethernet in an upstairs room. All lights are solid green. The main device is plugged in next to the modem downstairs. Lights are two solid green and ethernet light is solod blue.  All worked well until recently. The tv won't make an connection to the network, thus I can't access any streams such as Netflix. I got a new modem recently, should I have reset something? I have contacted both my provider and Samsung and no one can tell me how to fix it.
  • michaelkenward's avatar
    michaelkenward
    Did that coincide with the start of this problem?
    Reset the plugs, and set up from scratch.
    You don't say but I assume that you have already taken the Samsung TV through the network setup process. That is the obvious first step and is usually the way to deal with network issues.
    • MarthaCR's avatar
      MarthaCR
      I am not positive that it coincides with the new modem setup. I can't remember for sure if I have used this tv since updating the modem.
      1. I thought I read somewhere that if the ethernet light (the one that is blue) is not blinking, that there is no data travelng through.
      2. I have gone through the Samsung network setup several times with their rep.
      3. I just reset (with a paper clip) each part. Now the middle light does not light up on either one, and the left light on the adaptor in the remote location is solid red instead of green.
      • MarthaCR's avatar
        MarthaCR
        Have not received any more replies to help me. Anyone? Would hooking up  a Roku device help me with this?
