AMS_NGC
Jan 31, 2022Aspirant
SlowSpeed on Powerline AV200
Hi, I have connected my computer to XAVN2001 (Powerline AV200). The WiFi speed is 250+ (Downoad) and 15+ (Upload) But when connected to Powerline AV200 extension it is 11+ (Downoad) and 8+ (Upload...
- Jan 31, 2022
Powerline is sensntive to many things.
1. distance. The outlets might be next to each other but on seperate circuits. distance and crossing circuits is going to reduce speeds.
2. interference. many things cause interference. These include:
- old/bad/cheap wiring
- gfci outlets
- arc fault circuits
- surge protectors
- high draw appliances
- poorly made electronics that inject interference into the power line
- devices going bad
- cheap cell phone chargers
In my opinion, powerline devices are even higher overrated than wireless ratings. But when you have a connection its consistent.
Plus I'd look at a few reviews/test for powerline AV200 devices to see what a reasonable expectation is.
Jan 31, 2022Guru - Experienced User
- gfci outlets
- surge protectors
- devices going bad
michaelkenward
Feb 01, 2022Guru - Experienced User
AV200 are early generation devices. They date back to 2010. A lot has changed since then.
There are have three or four generations since then, 500, 1000 and 2000 at the latest. Plugs pre "1000" have 100 Mbps LAN ports, 1000s have gigabit.
- AMS_NGCFeb 01, 2022Aspirant
Thanks Michael!
will the AV 200. be compatible if I decide to get the latest?
- plemansFeb 01, 2022Guru - Experienced User
Powerline devices run at the lowest devices speeds. So if you're slowest device is the AV200, it'll hold the rest back.
Similar to the old "you don't have to out run the bear, just your friend" type of thing.
- michaelkenwardFeb 02, 2022Guru - Experienced User
Indeed. I could have added that the "200" claim is almost certainly as measured in ideal circumstances with none of the real-world electrical noise that most of us have to live with. And who knows what it measures?
Claims of "Bandwidth 200" Mbps can come down to 100 Mbps each way.
I would not persevere with a decade old technology that is slower than many modern Internet services?
