AMS_NGC's avatar
AMS_NGC
SlowSpeed on Powerline AV200
Hi, I have connected my computer to XAVN2001 (Powerline AV200). The WiFi speed is 250+ (Downoad) and 15+ (Upload) But when connected to Powerline AV200 extension it is 11+ (Downoad) and 8+ (Upload...
  • plemans's avatar
    Jan 31, 2022
    Powerline is sensntive to many things.
    1. distance. The outlets might be next to each other but on seperate circuits. distance and crossing circuits is going to reduce speeds.
    2. interference. many things cause interference. These include:
    • old/bad/cheap wiring
    • gfci outlets
    • arc fault circuits
    • surge protectors
    • high draw appliances
    • poorly made electronics that inject interference into the power line
    • devices going bad
    • cheap cell phone chargers
    In my opinion, powerline devices are even higher overrated than wireless ratings. But when you have a connection its consistent.
    Plus I'd look at a few reviews/test for powerline AV200 devices to see what a reasonable expectation is.
    https://www.smallnetbuilder.com/tools/charts/powerline/view
