Affezell
Mar 19, 2012Aspirant
Trouble to connect Dlink DCS-932L camera
Hi I have just bought a Dlink DCS-932L wireless camera and I have a NetGear Router WNDR3700v2 router. The camera works but some setups did not work correct. I have talked to Dlink support several tim...
fordem
Mar 19, 2012Mentor
First - is the camera working correctly on the LAN? If it's not, then call D-Link, the router has nothing to do with the problem.
From your description of that problem, I don't think the router is the culprit.
