Affezell
Mar 19, 2012Aspirant
Trouble to connect Dlink DCS-932L camera
Hi I have just bought a Dlink DCS-932L wireless camera and I have a NetGear Router WNDR3700v2 router. The camera works but some setups did not work correct. I have talked to Dlink support several tim...
Affezell
jmizoguchi wrote: I have 9 camera of these a port forwarding will be only for external access
I have no issues on live few external anytime for forwarding. motion detection are used in emailing from the camera so if the photo looks funny then you may have an issue with camera
make sure if you have latest one.
I had 2 with v1 and 7 was v1.5 or something and older v1 had most issues with hardware.
you need to contact dlink
Hello again
I bought the first camera for 3 weeks ago and the problems appear on that
direct. I have talked to Dlink support several times (15) and they have replaced the but with the same problem. So noew I have two cameras with exact the same error.
As I understand You have same type of camera so its easier to describe the problem.
1. As I say before when I try to setup the motion detection in the setup I
the picture is only a flickering colour picture and I can the the squares.
2. When I try to test send a epost to my mail I got message Invalid username
/password. If I use exactly the same epost setting in Dlink view Cam its
OK.
3. There is no picture in ViewCam and the word disconnect is in the picture
frame. If I try to to connect again I got word Connect in the frame but
direct after that come the text Disconnected.
I have Windows 7,64 bit and Explorer9
I have picture in the window Live Video in the Dlink setup program and on my IPhone too.
