Affezell
Mar 19, 2012Aspirant
Trouble to connect Dlink DCS-932L camera
Hi I have just bought a Dlink DCS-932L wireless camera and I have a NetGear Router WNDR3700v2 router. The camera works but some setups did not work correct. I have talked to Dlink support several tim...
jmizoguchi
Mar 19, 2012Virtuoso
sending via email only needs correct mail server, user/pass
I use gmail and it comes fine. It comes in crazy amount of motion detected pictures but never failed to work. I bought for going overseas while I have friend look my cat. I was able to watch live view as well
motion detection, I just pick few grids and works
try to use dlink or other iPhone app, I use different app which are seems to better because dlink iPhone takes longer to get data but I run in full resolution as well. Other than in week I use 1GB of cell data on my iPhone but works fine
as long as each camera as different port number and each port is correctly setup in the router then it should work.
