JPB93
Nov 22, 2024Follower
Trouble with PLP2000 connected to ARRIS Model DG3450
I connected the PLP2000 to the Arris unit then placed three PLP2000's in three other separate rooms of the house, pressed the connect button on the main PLP then ran through the house and pressed the ...
Nov 22, 2024Guru - Experienced User
If it all worked before they "turned off the wifi", it makes me suspicious that they didn't just turn off the wifi but switched your device over to a modem only mode type thing
