LWBChopper
Dec 19, 2019Follower
UK options for powerline WIFI plugs
I have a PLP1000 powerline network running and I'd like to add more plugs which are wifi capable - I cannot see any options on netgear UK site and amazon UK site, does anyone know if and where I can purchase these in the UK marketplace?
1 Reply
Netgear does not sell singleton plugs, only bundles.
You may be able to find another brand that does sell single wifi access point plugs.
So long as they obey the AV standard they should work. For example, I have just added a Develo plug to a Netgear "500" network. (I wanted a plug with two LAN ports.) Works just fine.
Look for a plug with the same, or better, network and LAN port speeds.
This looks good:
Devolo dLAN 1200 Plus Wi-Fi AC Add-On Powerline Adapter: AmazonSmile: Computers & Accessories
Unfortunately, Develo's documentation leaves something to be desired.
