PAC38
Mar 15, 2022Aspirant
Unable to add multiple powerline adaptors
We are trying to add a second set of powerline adaptors to a pair we have had for years. Once the first set is paired (whether an original pair, or a mix-and-match of one old and one new), it doesn't recognise any subsequent adaptors. The top light doesn't come on or flash at all. We have tried doing them one at a time in the same room, and it still doesn't work. Any advice please?
did you follow this guide?
https://kb.netgear.com/22165/Adding-a-powerline-adapter-to-an-existing-powerline-network
- PAC38Aspirant
Hi, Yes I did follow the guide, and have reset both sets of adaptors to factory settings. Of the 4 available adaptors, I can plug in any two and they connect, but when I try to plug in a third adaptor, either by swapping it for the second (child) adaptor, or by adding it alongside the other two, it doesn't work. The top light doesn't come on. Thanks!
what 2 sets do you have?
Where is it failing in the process?
Powerline devices are pretty compatible with other companies devices if they're on the same spec.
So long as you set them up properly, they should work together.
