strattsf
Nov 21, 2022Tutor
Use Powerline Extender for Ethernet Backhaul for Orbi System
I have an Orbi mesh system (RBK753) with 1 main and 2 satellites. One of the satellites is in a separate studio building in the yard. It is far enough away from the house, that the wireless backhaul ...
- Nov 22, 2022
strattsf wrote:
Is it possible to use a power line extender .... to create an ethernet connection in the studio, that I could then plug the Orbi satellite into, using the Powerline connection as a wired backhaul for the satellite?
Yes.
Not quite the same thing, but I have used Powerline as the wired connection to an Orbi router in AP mode.
michaelkenward
Nov 22, 2022Guru - Experienced User
Yes.
- strattsfNov 29, 2022Tutor
Thanks, confirming this worked! The speed of the internet connection using the Powerline connection as the backhaul, is about the same as the wireless backhaul when it actually connects, but I'm hoping it will be a more stable connection. I consistently get ~600 MB/s download at the router, but only ~50-60 MB/s at the Powerline extender. Not sure if that's typical or not.
- michaelkenwardNov 29, 2022Guru - Experienced User
A lot depends on the local mains network.
As you say, Powerline should be more reliable.
- SamirDDec 09, 2022Prodigy
That is about typical for powerline depending on the distance and tech involved (newest generations of powerline can hit 200Mbs ime). My older av500 units will hit about 50Mb.
- strattsfDec 10, 2022Tutor
Thanks Samir! I guess the Netgear product description is pretty misleading then. It says it can reach speeds of 2 GB/s. I totally get that's theoretical max, but that's a pretty drastic difference between theoretical and real world.
