2fast4some
Feb 04, 2021Follower
Using a switch to connect Starlink router and Google WiFi router in parallel
How should I connect a Starlink router and a Google Wifi router in parallel (setting aside the possibility that this might be a dumb idea to start with)? In a simple Starlink setup, a POE cable runs ...
michaelkenward
Feb 05, 2021Guru - Experienced User
I would not set aside the thought that it is a dumb idea. It is. Two routers are a recipe for disaster.
What is Double NAT? | Answer | NETGEAR Support
If your question is about the GS305P, you should try the right section.
That's probably here:
Switches - NETGEAR Communities
Questions about different brands of router are best taken to their support zones. There's not much that people in a Netgear group can tell you about Google and Starlink devices.
