LordHelpMe
Apr 08, 2023Aspirant
Using PLW100 with powerline AV200
The PLW1000 has two parts. On is attached to the router and plugged into an AC socket the other part is plugged into another AC socket and can send a wifi signal. I would like to know if I can buy ju...
LordHelpMe
Apr 10, 2023Aspirant
Than you for your help. Much appreciated.
Rick
LordHelpMe
Apr 17, 2023Aspirant
As an update. I found a Netgear PLW1000v2 on ebay. It arrived today. I plugged it into an AC socket and it worked fine connecting to my AV200. Granted the speeds aren't stellar but neither is my network provider. And another interesting point is that in the instructions for the PowerLINE WiFi 1000 set say that you can use up to eight extra units. But you can't buy separate units. Except, it seems, on ebay.
- michaelkenwardApr 17, 2023Guru - Experienced User
Some people have hit a wall when they connect a sixth plug.
- LordHelpMeApr 17, 2023Aspirant
Interesting but how do they get the six units? Buy six kits?
Three twofers. Or two three packs.
The plugs on the network will adopt the speed of the slowest. So you will see it all running at the speed pf the PLW1000v2.
I defy you to detect any difference.
