wyt168
Nov 28, 2011Aspirant
Using Powerline AV 200 Adapter Kit as a bridge?
I am wondering if I can use the adapters (XAV2001) in this kit as an Ethernet bridge, ie. will it support multiple devices hooked to the adapter via a hub? Or is it limited to only one device to an ad...
jmizoguchi
Nov 29, 2011Virtuoso
I wonder what is the typical throughput people get with XAV2001--what is the range?
range should be an issues. it's is the noise on the line an degrade the throughput in real time so never expect the MAX throughput that power line devices specs out. it will changes continually which you can see the LED of the power line devices too what is the throughput at that time.
manual has the LED indication for the speed or use utility see the speed
