wyt168
Nov 28, 2011Aspirant
Using Powerline AV 200 Adapter Kit as a bridge?
I am wondering if I can use the adapters (XAV2001) in this kit as an Ethernet bridge, ie. will it support multiple devices hooked to the adapter via a hub? Or is it limited to only one device to an ad...
wyt168
Nov 29, 2011Aspirant
StratmanX wrote: Were you unable to find the reviews over at SmallNetBuilder?
Yes, found the detailed comparison chart for various brands/models at the site. Thanks! Turns out the performance for XAV2001 is way down at the bottom. Should have done some more research before I jumped on the 2nd hand deal on Amazon.
