eisman
Dec 01, 2012Follower
Will a faster router improve powerline networking throughput?
I recently installed the bundled product including the XAV5101 and XAV5004. My goal here was to hopefully be able to stream fairly high bit rate HD videos from a PC on my network to a PS3. The pro...
jmizoguchi
Dec 01, 2012Virtuoso
Existing router should work fine but if actual speed gets over 100Mbps then Gigibit router would be good
Power line fluctuate all the time and indication of LED may not be good indication to take a fact.
If you really need solid speed CAT 5 is you want to use
