Sobehouse
Nov 23, 2022Aspirant
Wired ethernet download speed slow
Hello, This are my provider speeds (1000 down 50 up) I'm having Wired ethernet download speed slow (80 down 50 up). my wifi speed is faster then my Wired ethernet download speed , but just the do...
Nov 24, 2022Guru - Experienced User
What devices do you have? You told us nothing about your setup or what devices you have.
we don't know if you're using a router, a powerline adapter, a wireless extender, or what.
Details are key
- SobehouseNov 24, 2022Aspirant
I'm just using a netgear R9000 connected to a modem Harris SB8200 3.1
All the ethernet connections cables are Cat 8
- michaelkenwardNov 24, 2022Guru - Experienced User
What firmware is on the R9000.
I assume that "Harris SB8200 " is Arris SB8200. If so, standard cable modem.
What speed do you get if you take the router out of the picture, with speeds measured straight off the modem?
For more one your router, try the appropriate section:
- SobehouseNov 24, 2022AspirantI’m not able to measure the speed without the router connected, I don’t have any tools but this are the readings from the R9000 app and it’s also what I signed for from the cable company
- SobehouseNov 24, 2022AspirantThis are the wifi reading using several mobile devices
- plemansNov 25, 2022Guru - Experienced User
So I'm a little confused/needing clarity.
You said you don't have any ability to test the wired speed.
But your first post said your wired speed was slow and your wireless is faster.
That is indeed what your prior posts show. A wireless speed of 460mpbs (pretty good over wireless). And the routers speed testing showing the full 960 (ish) mbps.
So what's giving you the low wired speeds?
The fire stick and tv? If so, most tv's aren't gigabit capable. And none of the fire tv devices are. They're all 10/100mbps. Even the newest fire box with wireless 6E is only 10/100mbps.
So I'm curious whats giving you the slow wired speed for testing? Because it might not be gigabit.
