JasW1957
Feb 13, 2013Aspirant
Wireless network of XAVN2001 doesn't show up
I've properly connected my AV 200 adapter (XAV2001) with the wireless extender (XAVN2001), and am able to directly connect a PC via ethernet cable to the extender with good results. I want to conn...
Retired_Member
Feb 13, 2013I could be wrong but from what I read I don't think you can connect to this wirelessly. It's made to extend a wired outlet to save you from running cat 5 You could try an AP at one end which would then give you several lan ports and wireless access.
