JasW1957
Feb 13, 2013Aspirant
Wireless network of XAVN2001 doesn't show up
I've properly connected my AV 200 adapter (XAV2001) with the wireless extender (XAVN2001), and am able to directly connect a PC via ethernet cable to the extender with good results. I want to conn...
Retired_Member
Feb 13, 2013When I searched for info I only saw the xav2001 and didn't see the other model which is as you said.
I would think you would have a setup like other netgear routers or Ap's. Can you see it on your routers attached device list? if so try IP and see if you can manage it.
