JasW1957
Feb 13, 2013Aspirant
Wireless network of XAVN2001 doesn't show up
I've properly connected my AV 200 adapter (XAV2001) with the wireless extender (XAVN2001), and am able to directly connect a PC via ethernet cable to the extender with good results. I want to conn...
Retired_Member
Feb 13, 2013[LEFT]To set up your Extender wireless network: [/LEFT]
[LEFT]
[/LEFT]
[LEFT]1.
[FONT=Arial,Arial][SIZE=3]On the computer that is cabled to the Powerline Extender (XAVN2001), insert the
[/SIZE][/FONT][FONT=Arial,Arial][SIZE=3]Resource CD
[/SIZE][/FONT][FONT=Arial,Arial][SIZE=3], and install the Powerline Utility. [/LEFT]
[/SIZE][/FONT][LEFT]2.[FONT=Arial,Arial][SIZE=3]Follow the onscreen prompts:[/LEFT]
[/SIZE][/FONT][LEFT]•[FONT=Arial,Arial][SIZE=3]If you have a NETGEAR router, the Utility automatically finds the router, retrieves the wireless settings, and then prompts you to confirm the settings. [/LEFT]
[/SIZE][/FONT][LEFT]•[FONT=Arial,Arial][SIZE=3]If the router is
[/SIZE][/FONT][FONT=Arial,Arial][SIZE=3]not
[/SIZE][/FONT][FONT=Arial,Arial][SIZE=3]a NETGEAR router, or the NETGEAR router is not detected, manually enter the wireless settings. [/LEFT]
[/SIZE][/FONT][LEFT]3.[FONT=Arial,Arial][SIZE=3]Disconnect the Ethernet cable from the Powerline Extender (XAVN2001). [/LEFT]
[/SIZE][/FONT]4.[FONT=Arial,Arial][SIZE=3]Move the Powerline Extender to the area (or dead zone), where you want to extend wireless
[/SIZE][/FONT][FONT=Arial,Arial][SIZE=3]So are you saying this doesn't work?:confused:
[/SIZE][/FONT]
