JasW1957
Feb 13, 2013Aspirant
Wireless network of XAVN2001 doesn't show up
I've properly connected my AV 200 adapter (XAV2001) with the wireless extender (XAVN2001), and am able to directly connect a PC via ethernet cable to the extender with good results. I want to conn...
jmizoguchi
Feb 13, 2013Virtuoso
Yes, I should see the SSID broadcasting, but I do not. The blue LED on the front of the unit above the wifi symbol is on, which I presume means wifi is broadcasting. But as I mentioned in the first post, the extender's network doesn't show up as an available wifi network on any device I own.
As I also mentioned, I can't check the wireless settings in the XAVN2001 because the Powerline Utility doesn't recognize it. The manual suggests the following:
Your initial solution is to correctly setup two power line device to see each other then work on your wifi part.
