JasW1957
Feb 13, 2013Aspirant
Wireless network of XAVN2001 doesn't show up
I've properly connected my AV 200 adapter (XAV2001) with the wireless extender (XAVN2001), and am able to directly connect a PC via ethernet cable to the extender with good results. I want to conn...
JasW1957
jmizoguchi wrote: Your initial solution is to correctly setup two power line device to see each other then work on your wifi part.
I've already set the adapter and the extender up to see each other. That's why I'm able to connect to the Internet by connecting an ethernet cable directly from the extender to the PC. In other words, I have a regular powerline system working perfectly fine. It's the extender's additional wifi capability that I'm having a problem with.
