JasW1957
Feb 13, 2013Aspirant
Wireless network of XAVN2001 doesn't show up
I've properly connected my AV 200 adapter (XAV2001) with the wireless extender (XAVN2001), and am able to directly connect a PC via ethernet cable to the extender with good results. I want to conn...
JasW1957
Mar 03, 2013Aspirant
Mayagrafix wrote: The adapter with 3 leds (XAV2001) is hooked up via CAT5 to the router. It has no wi-fi capabilities.
The extender with 4 leds (XAVN2001) is the wi-fi access point, make shure to turn on wireles option (blue light LED is on) via the Powergear Utility software.
Use Powergear Utility Software to name network (SSID) and give name to both adapter and extender modules. It will also ask u to create pasword, remember it!
Should work flawlessly :o
Yeah, I should have updated here. Right after I posted, I tried again, and had no problem connecting to the network. Don't know what the initial deal was, with the devices seeing the network yet not being able to connect, but it was temporary (like less than 15 minutes). Everything works perfectly now.
