rbanks888
Jan 28, 2023Tutor
Would 200 Mbps Powerlines fail with 400 Mbps service?
When I started my 300 Mbps Xfinity Internet service last September, I connected my Mac via ethernet using relatively old Netgear 200 Mbps Powerline adapters I’d used for many years with another provi...
Jan 29, 2023Guru - Experienced User
Put the 2x powerline devices on the same circuit (try the same room). Its rare for them to fail. Its usually interference that causes them to not connect. Maybe something went wrong or is going wrong while you were gone and is now injecting interference into the powerline system.
So try them in the same room and on the same power circuit to see if you can get them to connect.
If they do, its something in the home causing interference.
If they don't, try them 1 more time but in someone elses home.
rbanks888
Jan 29, 2023Tutor
Thanks. I’ll try that.
