andydrew
Feb 25, 2009Aspirant
XAV101 - problem after firmware update
I have two XAV101's. They were working fine when installed out of the box. But I wanted to set up the network security and I couldn't seem to get that to work with the buttons, so I installed the Co...
cyclone
Apr 16, 2009Guide
I notice that on the XAV101 release note
Firmware Version 3.3.4 Features
1.Support Firmware Upgrade Utility with firmware file v3.3.4
2.Support power save mode (sleep mode). Device will go into power saving mode if RJ45 port don’t connected.
3.Improve push to security function and change the security button behavior as below
Did anyone check on the issue with ethernet cable plug in or without?
