andydrew
Feb 25, 2009Aspirant
XAV101 - problem after firmware update
I have two XAV101's. They were working fine when installed out of the box. But I wanted to set up the network security and I couldn't seem to get that to work with the buttons, so I installed the Co...
Dooku
Apr 17, 2009Novice
There is no issue with the firmware.
The new firmware includes a new power save feature, which puts the PowerLine units to sleep if there is no network activity from the RJ45 port.
- when a unit goes into the power saving, it would shutdown the powerline to save power, so it’s not connected through the powerline. The utility will not see the unit.
- all LED are off with the power LED blinking to indicate it’s in the power saving mode.
- with the active Ethernet link, the unit will wake up and resume the powerline connection automatically.
When you are using the Intellion utility you are effectively downgrading the XAV101 to an older firmware, so please go ahead and use the utility to update the units and see if the units work properly once you try to actually use the network connection.
