andydrew
Feb 25, 2009Aspirant
XAV101 - problem after firmware update
I have two XAV101's. They were working fine when installed out of the box. But I wanted to set up the network security and I couldn't seem to get that to work with the buttons, so I installed the Co...
aferrara
Apr 17, 2009Aspirant
Dooku you're absolutely right!
It works perfectly: as soon as a connection is estabilished the 3 leds start working again and the unit is seen by the netgear utility!
The awful thing is that I explained this problem to netgear support and they probably ignored this feature and therefore changed me two upgraded adapter :eek:
BTW Does anyone know ho to downgrade back to netgear 3.3.4 firmware from intellion, please?
Thanks
Thanks
