richlen2
Dec 07, 2009Aspirant
XAV101 not passing iTunes Sharing
I really like the speed of my Powerline network but the XAV101s are not allowing iTunes sharing. I have my iTunes Library on my iMac office computer and try to stream iTunes to my MacBook laptop in th...
Sharkus
Apr 08, 2011Novice
Me again!
I've just tried Home Sharing in my non-powerline environment, ie; WiFi, with my iMac running iTunes 10.2.1 (OS X 10.6.x) as the "Host" of the Home Sharing setup, and an Acer laptop running iTunes 10.x (not sure exactly what version, 10.2.1 is downloading as I type) and Windows 7. The PC laptop could see and access my Library via Home Sharing, so I know the setup works.
When the powerline adapters turn up I will re-test and post my results.
However, whilst researching things, I found this thread on Apple's support forums. I think the OP is the same on that thread and this one, and the key portion is the last post, which seems to indicate a solution to the issue. The post in question is:
Tracy, I would just like to thank you for your input...I got it to work. If the issue comes up again, here's what I did. I made sure the music library sharing was enabled on BOTH machines as suggested. It still didn't work. So after making those changes I unplugged the two adaptors, hit their reset buttons and voila the library appeared on m laptop.
These are REALLY FAST....much faster than wifi. My itunes library which takes several minutes to load over wifi took about 3 seconds. Thank you for all your help it is greatly appreciated.
So perhaps a reset on the powerline adapters is all that is needed?
