richlen2
Dec 07, 2009Aspirant
XAV101 not passing iTunes Sharing
I really like the speed of my Powerline network but the XAV101s are not allowing iTunes sharing. I have my iTunes Library on my iMac office computer and try to stream iTunes to my MacBook laptop in th...
SRZARR
Apr 08, 2011Novice
Sharkus, Thanks for your help. I had seen the same thread on apple as well. I gave the reset a shot, but it didn't seem to work. I will give it another shot. Also previously, I had turned on the powerline adaptor's security in case the would help, but no luck.
So were you able to get your itunes libraries to share with the powerline adaptors?
