richlen2
Dec 07, 2009Aspirant
XAV101 not passing iTunes Sharing
I really like the speed of my Powerline network but the XAV101s are not allowing iTunes sharing. I have my iTunes Library on my iMac office computer and try to stream iTunes to my MacBook laptop in th...
oysty
Aug 17, 2011Aspirant
I am having the same problem as well. I have raised this with support and the response I have had so far is
"if you are able to connect to internet using the power line adapters and not able to connect to Itunes, means that there is no problem with the power line adapter"
Has anyone else found a resolution to this issue?
