kdogg
Dec 13, 2011Aspirant
xav101 v2 firmware upgrade
I was just trying to upgrade the firmware of my xav101 v2 and ran into a snag. The upgrade program downloads and installs fine, but when I run it there are no visible buttons to press. The instructions say "press next to continue" but there is no next button. I tried uninstalling and reinstalling, but it didn't help. I'm running windows 7 64bit. Has anyone else run into this or have any suggestions?
- tpcguyGuideIs this the FW upgrade utility that you used?(http://support.netgear.com/app/answers/detail/a_id/19580). Make sure that powerline devices are connected on the network. Powerline LED's on both products should be lit as well.
- kdoggAspirantYes, that's the one. The devices are on and fully operational. I feel like the issue is in the utility or compatibility with my system rather than the hardware. I have attached a screenshot of the utility in action, or inaction depending on how you look at it. Something doesn't look right about the utility...
- kdoggAspirantProblem solved. The windows font size was set at 125%. I set it back to 100% and the window resized, showing everything as intended.
